KewlBird
- Oct 6, 2007
- 247
Hi everyone, I just purchased a 1975 85hp to replace my 1963 40hp. The motor looks excellent under the cover. I couldn't get it started so I rebuilt the carb. and then checked the spark and #2 was not firing. So swapped couple of wires on powerpack and the spark plug fired. Easy solution: New powerpack. Got the new powerpack in today but the motor won't fire up. I get spark on all 4 with the spark plugs out of the engine and no spark with the spark plugs in the engine
. I used an inductive pickup to check if they're firing when in the engine and they are not. If I pull a plug out that plug it will fire outside and I can verify that the inductive pick-up tool is working. The rest of the plugs that are still in the engine are not firing
. The plugs don't look too bad, they're not new and the spark when the plugs are out of the engine is very strong. The battery is fully charged and the engine seems to be rotating fine. The compression is between 107-114 on all cylinders. I also sprayed a little fuel/oil in each cylinder to verify that it still isn't fuel issue (I know the inductive pick-up tool isn't showing a spark but who knows) and still didn't do anything. Where do I go from here?
Sorry for the long post and thanks for any comments.
