jtexas
- Oct 13, 2003
- 8,646
Putting the cranking batt in the boat Saturday morning, hooked up the negative leads, touched the positive to the post and *POP* big old spark. I'm talking about the main leads from the starter motor and the engine ground. <br /><br />I visually inspected the cables, couldn't find any problems. Then (luckily before I opened up the throttle box) realized I had the black cable connected to the positive post. Hooked it up correctly, and everything worked normally after that.<br /><br />With the negative cable connected to the "+" post, measured 12.0 volts from the positive cable to the "-" battery post, about a .65v drop vs. voltage across the battery.<br /><br />I know it sounds like this should be posted in "Stupid Human Tricks," but I'm very curious about whether this is normal and why it does that.<br /><br />Any opinions, insights, comments?<br /><br />thanks,<br />jtw
