Speaking of TB V?
NHGuy
Where does the distributor ground attach? i just ran my new engine and it's not running right. And I do have and extra black wire with a loop terminal right by the distributor.
Ayuh,.... There oughta be a little hole, Up from below in the main housin',....
Maybe midway 'tween the rim, 'n shaft,...
NHGuy
This ignition originated with a 1997 4 barrel 350 Mag which later had heads done at a Mercruiser shop. I bet they used the 10-32 x 1" hold downs then and left off that ground.
There is a ground on the distributor by the ECM and knock control module. But since the distributor is made of aluminum I am going to do the 1.25" through-bolt and add that ground. Aluminum isn't the best conductor.
