Special prop tool? lower gearlube holes?
michboater
Just bought a new boat (see signature)<br />As I was getting some lines, anchor etc, an old man came up and said I should remove the prop when transporting it so it doesnt get stolen...cant find out how to get the bugger off, that man said also that it took a special "Key" because it looks like it has some sort of prop lock. Well I did not receive this Key with the boat purchase. Where can I get this key? base looks like a 2-3" ring with steps in it.<br /><br />Seperate note, found the fill/drain hole for the gear lube but cannot find the overflow top hole? whats up with this? How do I know when it's full?
wilde1j
Re: Special prop tool? lower gearlube holes?
I would contact the prior owner for the key if it's got a prop lock.<br /><br />Unless you you park the boat in a high cerime area, I wouldn't bother removing the prop for transport, especially if it has a prop lock. Generally the props at risk are almost always SS ones, b:c the list for >$300 ea.<br /><br />Vent/fill screws are usually located on the starboard side, one at the lower section of the gearcase, the other near the cavitation plate and they are identical, slotted screws.
michboater
yea its a stainless model. Bought boat from dealer, no contact avail for prev owner. <br /><br />For the life of me I cannot find the upper gearlube hole?
