Hey folks,
I've got a '74 electric-shift Stringer outdrive, and I'm trying to get to the forward-gear clutch-spring to replace it.
I see in the manual that I'll need a 'special tool' to grab the splines of the drive shaft and turn it, while holding the lower pinion-gear nut, in order to remove the pinion gear, so I can pull the forward gear and spring assembly out of the case.
Has anyone any suggestions for alternatives to this tool? Or is it something I should be able to find cheap someplace?
Thanks for any help...
