So I've been working most of the summer - off and on, on my 1981 Hydrasports 2100 CC (Center Console). It's a Kevlar hulled boat and weighs 2100 pounds. Originally, it had a Johnson 235 on it, but that motor was shot, so I took a solid 1977 Evinrude 140 that I had on an old Renken 19 footer (only 1300 pounds) and put it on the Hydrasports. The motor originally had a 3 blade prop that I think had at least a 17 pitch (maybe even 19, there were no markings on the old prop), and it would put the Renken on a plane, even fully loaded, in nothing flat, and go as fast as I felt comfortable going. The prop was pretty chewed up though, and when I put the motor on the Hydrasports, it would cavitate - because the motor was a bit higher out of the water than it was on the Renken. So I put a 4 blade 15 pitch Solus prop on it and at the recommendation of the Solus guy. I've now got the entire rig running pretty well on the heavy Hydrasports, but the boat is, as you might suspect, slow. I've fixed the tachometer and at Wide Open Throttle, it's running at 5000 RPMs but still struggles to get on a plane and noses up a good bit. There's no cavitation with this new prop. My speedo isn't working but even when it planes out, I don't think I'm getting more than 20Mph out of the boat. If it's just me driving it, it'll plane out after 15 seconds or so. If my wife and two small kids are up front, it does about the same.
At the recommendation of a boating buddy, I'm strongly considering a hydrofoil like the SE Sport 300
SPORT MARINE TECHNOLOGIES SE Sport 300 Performance Marine Hydrofoils at West Marine
I don't care if the boat goes real fast, but I want and need it to go faster than it is.
So I suppose my questions are:
1. if I'm getting 5000RPMs at WOT, does it make sense to go with a bigger pitched propellor?
2. These foils seem to help folks in my situation. Anyone have any experience like mine and can offer some advice ?
3. Is the motor (which tests 120 on all cylinders), just not powerful enough for the heavier Hydrasports?
Thanks very much.
Chris Dixon
