Went out this morning and ran my boat with a speedo, against my GPS in different conditions to see how accurate the speedo would compare to the GPS, here are the specs and the data collected.
Tested @ Bushy park (freshwater resevior side and salt water side) in Goose Creek South Carolina. 74 degrees outside with 70% humidity, water temp @ 63 Degrees. Wind speed was 1-3mph.
1998, 14.5' BayRayder fiberglass side console V-hull with 1998, 25hp Mercury, 2-stroke running with a 3 blade, 13p Aluminum BlackMax prop. Motor is 114 pounds, boat is 650pounds, im 220, gas tank was 34 pounds, 2 batteries @ 81 pounds total and 38 pounds of gear. 10 gallon live well filled with water.
Faria Speedo with Teleflex pitot tube. Tube is 10' long from pitot to guage. Against Garmin Explorer GPS handheld.
Results: Fresh water lake at WOT (5,900 RPM's) with no water movement was 32 MPH speedo, and 32.1-3 MPH garmin
Fresh water @ Cooper River junction with 13,000 CFS running into the river from the lake. Current speed was 2 MPH (confirmed by drifting W/ GPS): Upriver: 32.0 MPH GPS and 32-33 MPH speedo (light water pressure on pitot tube). Downriver: 32.1-3 MPH GPS and 32 MPH Speedo.
Salt water @ Cooper River with tide moving out @ 5 MPH (confirmed by drifting w/GPS). Upriver: 31.0-1 MPH GPS and 32-33 MPH Speedo (spiked when hitting current pockets), Downriver: 33.0-2 GPS and 32 MPH Speedo
Goose Creek @ Cooper River (Salt Water) with tide going out @ 12 MPH (confirmed by drifting w/GPS) Upriver: 28-29.8 MPH GPS and 32-34 MPH Speedo. Downriver: 32-33.8 GPS and 32 MPH Speedo.
I think it's safe to say that if a speedo is properly hooked up it will read just as accurate as a GPS if you figure a 3 MPH gain or loss depending in conditons. Obviously this data may only be able to used on a rig the same style and speed as mine, as im sure hull design, lenth, weight, OB or I/O size, and speed all have different impact on the accuracy of the data, as well as temperature and altitude.
