speedometer help
huntingdeer
is this on right?Sorry i dont know what its called but i had to replace it.i took it out for a test run and it still dont work.It may be on backwards:facepalm:?image.jpg
tpenfield
Re: speedometer help
pitot pick-up
not right
might just need to be 'flipped' to the down position . . . or . . . could be mounted upside down.
sphelps
It needs to be flipped down for sure .. I think you can test it with a strong stream from the water hose ..
tpenfield
should be like this . . .
180shabah
Speedo is nothing more than a pressure gauge, the pitot needs to be flipped down into the water flow after the boat I'd off the trailer.
