Hi.
I recently found the rubber tubing on the back of the speedo had come off. I re-installed it, and the speedo is still not working. If I attach a piece of tubing to the speedo and blow on it, the needle only moves up to around 5 MPH with me trying to apply as much pressure as I possibly can using my mouth. I know from previous experimentation on a work-related thing that when you blow as hard as you can into the end of rubber tubing, you are applying around 1-2 psi. The line going back to the outdrive is not plugged, I can blow air through it fairly easily. I'm very surprised that it would require this much pressure to move the needle, considering the little hole on the front edge of the lower unit is only about 1/8 in diameter. What's going on? The speedo is a VDO 0-75 MPH.
