Speedometer pickup on Force 150 outboard
Mathewpt
Hello, I recently obtained a 1993 Glastron with a 150 Force outboard. The motor runs great, but the speedometer is not working. I *suspect* the speedometer input is plugged. I've traced the black tube from the speedometer gauge back to the outboard, and see where it enters--but I'm unsure where the input is....there's no obvious hole on the front of the lower unit. Where is the speedometer input located? Do I have to remove something to check to see if its plugged with debris or similar?
jerryjerry05
No Title
The speedo pickup is on the boat.
Look at the pic.
Force didn't put the pickup in the drive until after 94-95
