I have a 2003 chaparral 180ss its a 3.0L Alpha drive, The speedometer was not working when i bought it so i tried to blow from the gauge back to the drive through the hole in the leading edge of the drive, and a little water came out and some grass. Anyways i was blowing it with nitrogen and it just seemed to still be clogged so i put more pressure on it and i heard a pop and it sounds like it popped the hose off on the inside of the lower unit.I just realized there was a quick disconnect under the lower unit where i could have taken it loose but got inpatient and didnt see it.I was wondering if i run the boat without the hose being attach to the other side of the pressure hole will it mess anything up, and also can i take the lower unit off and re attach it.
