Speedometer question
Rourk89
Hello all, new member, first post. I recently bought a 1990 Lowe 1620V fish n pro. Recently as in October last year. have used it once last year then put it away for the winter. I am about to bring it out of storage to start doing some work on it that I knew I would have to do and once of those is to get the speedometer working. The previous owner could not tell me if it had a paddle wheel or a pilot tube. Is there a way to figure out what was originally there? Can I put whatever I want on there?
you can put what ever you want, however most likely its a pitot tube and the tube is broken or the pickup is plugged.
wrench 3
Welcome aboard.
The pitot tube uses a hose. (or plastic tube) A paddle wheel is electric and will have wiring.
You didn't mention what engine you have but a lot of them have a pitot tube set up built into the drive.
Rourk89
Thanks for the info. It is a 40 horse Johnson. There is a white plastic bracket that the guy told me where a paddlewheele or pitot tube would go. I will try and take a picture of it tomorrow to confirm
wrench 3
The plastic tube or wires would come through the transom above the waterline over top of that plastic bracket.
Silvertip
Look at the back of the speedometer. If you see a couple of wires and one larger, usually black plastic tube you have a pitot speedometer. The wires are for the internal light. If there are more than two wires and no plastic tube you have a paddle wheel (electronic) speedometer and need the paddle wheel.
