agallant80
- Oct 25, 2010
- 2,328
Bondo made a comment in another post and It got me thinking of how much money could be wasted on a boat to go over and above
I have seen people do the following every year to their boat even though merc does not say to do it every year
tstat $14.75
plugs $6.08 X 8 = $48.64
impeller $22.31
oil change every 25 hours instead of 100 (assuming 100 hours a season) (4 filters at $8.99 = $23.96) (4X mobil1 15-50 at walmart @25 each =$100) $123.96
Air does freeze so I need 5 gallons of the pink stuff 5 gallons at $3.97 = 19.85
Gear lube change every oil change (4 because we put 100 hours on the boat a season and change every 25) $12.99 X 2 quarts per change X 4 changes $103.96
Fuel Filter (mine is every 3 years according to merc) $78
Total Spent $411.47
If you did it according to the manual with gear lube once a season, oil once every 100 hours skipping impeller and plugs because they are not needed this season you would be spending lots less.
It's the 2ndary Marine marketers that developed the antifreeze trick,...
It's a Sales Tool, 'n little more,... they know Boaters are waayyy to anal 'bout some things,...
Spark plugs, 'n t-stats are thrown out by the Millions, for no reason at All,...![]()
tstat $14.75
impeller $22.31
Total Spent $411.47
