spicer5-1306X u joint in alpha 1
djvan
With a little research and this site I was able to determine that the above mentioned spicer number is a suitable replacement for my alpha one u joints.
My question is this:
The joints that I removed had the grease zerks on the face of the joints. Picture an "X", the zerk is where the to lines cross.
On the spicer joints the zerks are like most car ujoints and between the caps and slightly offset.
Will this cause clearance issues?
I'm not worried about greasing them as I'm pretty sure I could use a needle tip for my gun.
Any help here is greatly appreciated.
Dougv>
Don S
Re: spicer5-1306X u joint in alpha 1
Yes, they will work like that.
djvan
Thanks Don, that was quick.
DougV>
