Spilled Oil
Regal-89
Well I decided to change my oil this weekend, all was going well untill I took the oil filter off with greasy hands. Low and behold I dropped the filter and spilled oil everywhere. Its all over the floor beside the motor, also on my power steering pump, and then of course it feel into the motor cavity. So last but not least if drained on my bilge pump. So with one fell swoop I have managed to destroy everything. Does anyone know of something that can get oil out of carpet, and off everything else that I have managed to trash?
JB
Re: Spilled Oil
Soak up the "loose" oil with cat litter or similar absorbent clay particles.<br /><br />Then saturate the oily areas with Gunk or similar cleaner.<br /><br />Hose away the Gunk and it will probably be cleaner than ever.<br /><br />Good luck. :)
lakelivin
Re: Spilled Oil
What will Gunk do to carpet? Dawn dishwashing detergent is supposed to be good on grease, wonder if that might be strong enough to do the job on carpet but a little safer? (no experience with this, thinking out loud)
mellowyellow
Re: Spilled Oil
auto-dishwasher detergent is a good combo,<br />absorbs and disolves.
ziggy
Re: Spilled Oil
i used dawn dish washing soap on my carpet in my boat. carpat was no more damaged when i was done than when i got it. but did get up mold and 2 summers of just sitting gettin wet, moldy and stained with decaying sticks leaves and the likes. used a bristle scrub brush with the soap. bet it will do at least some good on the carpet oil. displaces it. lots of water too.
crazy charlie
Re: Spilled Oil
For tough stuff like that ,I use either greased lightning auto formula or Castrol degreaser.I think they both come in purple containers and can be had at Walmart.Charlie
jlinder
Re: Spilled Oil
I have had good experience with clothes detergents (i.e. - Tide) and a stiff brush on car upholstery. Wonder what it would do with boat carpeting>
cuzner
Re: Spilled Oil
Wnat ever you use make sure you rinse it all off your carpet.I"ve used a paste of tide + water on the area effected, rub in and let it soak up oil for bit. Then get as much of that off as possible, sprinkle some more tide and scrub. should get rid of stain.Charlie probably has a better idea though. But I would get some tide on it till you get wal-mart . Jim
garycinn
Re: Spilled Oil
I second the vote for orange citrus / greased lightning style cleaners for grease.
WillyBWright
Re: Spilled Oil
I know this sounds silly, but stuff an athletic sock with styrofoam packaging peanuts and toss it in the bilge. That'll eventually soak up the oil there if you can't get to it to clean it by hand. It'll also help keep the bilge clean. Most sterndrive and inboard boats eventually get an ugly layer of oil residue back there. Water that gets in there floats some of that up, but then it recoats when the water drops. The peanuts won't soak up water, but they will soak up the oil. If you have an automatic bilge pump switch, tie the sock somewhere where it won't foul it. Otherwise just let it flop around back there. The sock will also help wipe some of the residue that sticks to the bottom just from movement.<br /><br />You can also purchase such a thing but I find that few dealers stock them. They're a foam-like material that resembles fiberglass wrapped in plastic fishnet stuff (like bags that oranges come in). The foamy stuff does a good job of soaking-up the oil, but that fishnet don't do much for cleaning.<br /><br />I sould add that they have to be styrofoam peanuts. A lot of those are made with cornstarch now and degrade on purpose. Those won't work. If you want to get technical, I think they're extruded styrene peanuts. Essentially the same material, but styrofoam is a bunch of little balls of polystyrene pressed together. That works too but not as well and them little balls scatter everywhere if they get out.
Ralph 123
Re: Spilled Oil
I am with CC - Greased Lightning is PFM! (pure flippin' magic). It is one of those rare products that under promises and over delivers. <br /><br />I have some scatter rugs that I use to cover the boat floor when I am working on it. They were caked with oil, grease and dirt - I mean they were black as the ace of spades. I sprayed them with GL, took a hose to them and they look brand new! Amazing! (check for color fastness before going nuts with it)
umblecumbuz
Re: Spilled Oil
I go for JB's Gunk. Big bonus is that it does not froth, and is easy to hose out completely. Do the motor with it at the same time.
sangerwaker
Re: Spilled Oil
Goop non-pumice hand cleaner works very well, too. I have not used it on carpet, but takes grease off of clothes excellent. Rub some on the affected areas, and throw a little dab in the wash machine with the rest of the clothes, and the grease or oil is gone. I'm sure it will work well on carpet also.
rwidman
Re: Spilled Oil
Consider a spray "degreaser" for metal parts, any of the above suggestions for fiberglass and carpet. If it's nice carpet you might want to have it cleaned by a professional carpet cleaner.<br /><br />Do your best to avoid contaminating the ground or water with the spilled oil and cleanup products, try to contain them and dispose of them properly.
lakelivin
Re: Spilled Oil
Originally posted by WillyBWright:<br /> ...The peanuts won't soak up water, but they will soak up the oil....<br /> <br />I sould add that they have to be styrofoam peanuts. A lot of those are made with cornstarch now and degrade on purpose. Those won't work. If you want to get technical, I think they're extruded styrene peanuts. Essentially the same material, but styrofoam is a bunch of little balls of polystyrene pressed together. That works too but not as well and them little balls scatter everywhere if they get out.
Man, I'm learning some interesting stuff in these forums. How do you tell the styrofoam from the cornstarch peanuts?
WillyBWright
Re: Spilled Oil
Styrene ones are either white or colored, shiny and smooth and taste like communion wafers. Cornstarch ones are beige and rough and also taste like communion wafers. ;)
Boomyal
Re: Spilled Oil
Ditto to what JB recommended. Soak up the excess, remove absorbant then spray with Gunk. Wait a few minutes then spray off with a high pressure stream. After that you can use a soap product or high alkaline degreaser. There is not much that Gunk will hurt and it is much more effective than any of the high alkaline 'degreasers'.
