Took the 22' Pontoon out the last couple weekends and seem to have an issue. The motor is a Suzuki 70 fuel injected and I can run 20mph at about 4400 RPMs. The issue is that every now and then at or near full throttle the motor will jump to 7000 RPMs but the MPH slows down. It's similar to a car doing a burnout so to speak, lots of power but not really going anywhere. I can throttle down and back up and it may or may not fix it. The only "fix" I have found is to put it in reverse then back in forward. It's like the propeller is turning faster than the water can be churned or the propeller is out of the water. It only does this every now and then. Rode for 4 days and did it about 5 times. Any ideas?
