spinning starter but not engageing
I've studied this problem with previously posted questions and answers and removed the starter cleaned up the shaft,bendix and lubed with lith grease and still the starter spins but dosen't engauge if you crank the starter long enough it will finally engage but I don't want my starter burning up on the water that would suck swamp water with the wife and daughter on board. paddling a 16.8' fiberglass i/o isn't any fun.<br />By the way I am a fireman and we tend to over do things un intentionaly so is placeing too much grease on the shaft going to hurt anything? REMEMBER GO BIG OR DON'T GO
Paul Moir
Re: spinning starter but not engageing
You're supposed to *lightly* oil the bendix shaft with light machine oil, not grease it. It does work off of inertia afterall.
whoops, any easy suggestions on how to remove the grease with out tearing the whole thing apart again? @#$%!&^* it! I was up untill 5 in the morning trying to fix that p.o.s. are there any more reasons the starter would spin and not engage because it was the same problem before I got my fingers on it.
Spring
Make sure you have a known good fully charged battery and at least 12.33 volts at the starter cable post.The starter has to spin fast enough to "throw" the starter gear up an inclined bushing. You might try brake cleaner and a small brush on the grease. Otherwise, it will have to come apart again,sorry.Hope this helps
thanks spring I checked it previously and got a reading of around ten something not too shure if the reading was very accurate or not but I charged it up and it needed it but didn't fix the problem . could the altanator not be charging the battery correctly :(
Mod2
Wires....transferring your post over to the I/O Troubles and Repairs forum.
Bradster941
Wires, even if the battery is up to charge and you read 12 + volts at the starter, when engaged, the voltage / amp draw can drop significantly if you have dirty, corrosion on the contacts in the circuit causing the problem. This includes the ground circuit as well.<br /> As for the grease, a quick way to clean off the bendix is starting fluid. Its like cutting with gas but evaporates off quickly.<br />Ps. The alternator only works when the engine is running. <br /> :D
