Spirit 40
Hosegsp
I have already posted this in the other brands catagory and got a tip it may be better answered here. So here goes....
I boat an older lund boat last year that came with a Spirit 40... it runs ok it needs the carb pulled of and cleaned and someone mentioned i should replace the impeller as well...... well the problem is finding parts.... i know some suzuki parts interchange.... but what suzuki motor??? i will get the numbers off the motor when it stops raining and post them....
What else should i do to freshen up a motor that has been sitting for a couple of years? other than new plugs and lower unit lube which i changed when i bought it.
thx for the help!!!
deejaycee_2000
Re: Spirit 40
You can clean the carbs .... soak in carb cleaner overnight and blow out with compressed air .... You can find parts online at brownspoint.com, the 40hp suzuki should be the same, just e-mail them and make 100% sure ....
