Splashing 1971 Evinrude LARK 50 HP
I am having a problem with power when more then one person is in the boat. Its a 1970 15 ft Crestliner (Fiberglass) with a 6 gallon gas tank, a battery and two reclinable seats in it. Its a 50 HP evinrude lark (1971) and has good compression.
I have noticed that the motor splashes to the sides while at full throttle. Take a look at youtube video - Is my engine too low in the water? causing the splashing? or is this normal?
http://www.youtube.com/watch?v=PS6qSNny8nA
Vic.S
Re: Splashing 1971 Evinrude LARK 50 HP
The engine height should be such that the anti ventilation plate above the prop is about level with the bottom of the transom.
I double checked it several times. It is in line with the cavitation plate.
jimdd810
did you try trimming it out a little. If dont have tilt and trim move the pin out 1 or 2 and try that.
