Re: Splicing red plug to post 1995 wiring harness
I am in the same boat I got a 1997 ocean pro 90 hp with controls, but the motor has a knock. so i replaced the motor with a 1995 115 ocean runner. and left the controls installed.
luckily my buddy gave me his take off from his pontoon a 1988 88 spl with the newer controls and it came with the adapter harness!! problem was it is like 15 feet long!! and i have it coiled up at the motor, since I already had the rigging hoses set for the motor and run under the floor.
I looked around for a shorter version of the harness and it is VERY hard to find , and they are like $150 plus!
the kicker is the 6 pin modular connection plug went bad twice and I eventually just cut it out and soldered the wires!! so i dont have a means to unplug it now!
which way are you thinking of going? cutting the ends of your harness and splicing a matching big red plug? or cutting the big red plug out and splicing in all the modular connectors?
or just splicing the wires direct sans plugs ends??
before that one connector went bad, i was thinking of just shortening my harness,
good luck
let me know if you find a cheap sopurce of adapter harnesses
they ahve soooo many different versions!!
bob
