Split block mercruser 140
Status
Not open for further replies.
barney
i spoke to a machine shop and they said it would probibly leak if it was welded. I am looking for a new/used workable block. It is a 1981 mercruser 140hp,181ci any info would be great
a.d.mobile
Re: Split block mercruser 140
Does the motor get water in the oil??? if not pull enginge and have welded if you are not going to sell the boat. If you sell it fix it right or notify buyer. It might dribble from weld but it will rust closed fast or cover with epoxy. just a easy way out.
barney
I have the block on my bench and a piece has broken clear and the split has gone through the cylinder head bolt hole, I'm in deep caw caw, thanks for the reply.
f_inscreenname
Go to a junk yard and get your self a new one. You are already this far. Go all the way. I would only weld if I didnt have to pull the motor.
barney
Is the 3liter block the same as any other GM product. The junk yards where I live only deal with autos. I can't seem to source one in my neck of the woods, can any one point me in the right direction?
barney
I understand that a block is a block but does any body know if GM put this particular block in any passanger cars,trucks or any thing else. 1981 mercruser with a 181ci made in Mexico block #277087 I think it is a 3 liter.
i don't know if this helps, but, i've got two of these in my garage that i don't need or want..... one dressed with alpha asessories, the other with Mod. 1 parts....<br />the aplha dressed motor is a runner, with 135/145lbs compression....<br />the Mod.1 dressed motor has about an hour run time on it....BUT, a defective piston broke,+ took out a bore... now needs a sleeve to be a running motor... i'd put 4 new pistons in because the other three are the same part# as the broken one....<br /><br />Bondo
Trent
If Mr. f_inscreenname knows of a junkyard (auto) that has these I sure would like to know!! <br /><br />The Mercrusier 181 was Mercrusier only!<br /><br />Now he is correct in saying A block is a Block when it comes to the 152 cid. <br /><br />It went into the 110/120 Mercrusier. <br /><br />Look for a 1965 Chevy II Nova and its the same.<br /><br />The Merc 470/165(four cylinder), 485, 488, were Merc only. It was their attempt at making their own engines...
barney
Bond-o how much for the block (s) and is the 181ci considered a 3liter.
Barney, Yes 181cid is 3litres.... i'd like to get a $1000. out of the running engine.... the 1 needing a sleeve ?? do you want a completely dressed engine(manifolds,carb,alt,wiring,ignition,etc.) or just a stripped long block, or a stripped bare block, ????<br /><br />email me direct at bondo@twcny.rr.com<br /><br />Bondo
Status
