Good Trout To You Sir
- May 22, 2018
- 85
Hoping someone can shed light on what has become a recurring problem: unpredictable inability to start cold motor AND sometimes the inability to restart the motor after a break of 15 minutes after use. This is a 2.5HP (E3RC). Problem has become more frequent and more serious coincident with a Seafoam decarb. This motor utilizes a small fuel primer in lieu of choke mechanism. On Saturday after 40 min of operation at variable speeds punctuated by brief stops and restarts, motor refused to turn over after a 20 min break. Here's what I know:
Compression reasonably good -- "wet" compression in cold cylinders about 120 psi. Top and bottom readings differ by less than 5-8 psi.
Just changed plugs - they are proper plugs with proper gap. Good spark.
Fuel primer built into carb is difficult to "feel" for correct operation. Either I overpressurized the entire fuel system or just the carb fuel primer b/c I smelled fuel and could see it dripping out of the cowling. Removal of vacuum tube from the small port on carb top to redirect primer stream directly into carb throat enabled a restart. After I had it restarted I kept it WOT to make my run back to the dock. During WOT, motor seemed to function normally.
Does motor likely suffer from fuel system blockage, air system blockage, air leak, or something else?
How can I rule out possible causes to isolate the issue?
Thanks!
Thanks!
