sport jet 120 water in cylinders
dougcaster
We have a 1995 Sport Jet 120 that was overheating. We flushed the engine and got water in the bottom 2 cylinders. We drained the cylinders but now we continue to get water leaking in the bottom 2 cylinders. Is the problem with the head gasket or is there something else we should check first.
Anders67
Re: sport jet 120 water in cylinders
Hi.
If you oveheated it change the Head gasket . It can also be the manifold gasket. Change both, they are not so expensive and you can do it with engine in place. Take a couple of ours.
Put the top/head on a scale ore something straight when you have taken it off, and see so it not have been bent/twisted of heat.
Capt Ken
You are probably going to find corroded holes in the exhaust manifold.
aksor
Yup
