Sport Jet 90 Wont Move
JRP1983
I just bought a 1994 Donzi medalion 152 with the Merc Sport jet 90. The engine starts right up and runs perfectly, but once i put it in the water the boat wont move over 5 mph. I am pretty sure the revers gate is up(unless it falls once i start the boat) There is about a 1/32 to 1/16 inch gap between the impeller and housing. I pulled off the ride plate and the Gasket looks O.K. The engine revs to around 5200 rmp and the impellor is spining because i can see the water shooting out of the back very fast ( could it be air too)...i dont know why the boat will not move...Any help would be appreciated Thanks Justin
bret walters
Re: Sport Jet 90 Wont Move
if the reverse gate is opening when in forward and there is no debris in the pump housing the problem is most likly a warped or cracked ride plate. if this is bent it wil vent exhaust gas into the impeller and cause it to cavitate.
