Sportjet 175 Ignition Problem
diveguy
After a great day out on the water, my sportjet 175 started cutting out, and died as if it was running out of fuel (it wasn't). I limped it home, with about 1800 RPM the most I could get out of it. At steady throttle, it occasionally sputters up to about 2400 rpm for a few seconds, then back to 1800. Any more or less throttle kills the engine, and it's hard to restart.<br /><br />After sitting for a day, it started and idled okay, but again cuts out once I get going, and I can't get it over about 1800-2200 rpm without killing it. <br /><br />I haven't had any problems with this engine up to this point, gas tank, oil are all full, and I'm certain something went bad on the ignition side.<br /><br />Any ideas? Is this something I could potentially fix myslef?<br /><br />Any thoughts/assistance is appreciated!
affa
Re: Sportjet 175 Ignition Problem
Hi<br />Im not sure what a sportjet is, what engine does it have?<br />Regards<br />Affa
diveguy
Mercury Sportjet 175 - V6, 2-stroke motor used in many riverboats.
