I have a 94 Bayliner Reflex with a SportJet 90 (Mercury/Force). I pulled all the plugs and did a compression test. The results were not good 120 110 and 90. After I did the test the boat would not start or even fire. I did a voltage check on the low voltage side of the coils while turning over the engine and the meter didn't move. I noticed in a forum response that it was recommended to ground a plug wire if it was going to be removed while running the engine. Failure to do so could damage the ignition system.I was turning the engine over but not actually running it. Could what I did have damaged something? If yes what is the most likely component? I don't see anything red under the flywheel so I suspect I have the old style stator. Should I be able to see the stator without removing the flywheel?<br /><br />I have ordered the service manual and it should be here this week. I sure wish I would have waited for it before starting any work.
