spray can "de carb"
plugger
if this sounds dumb so be it.....<br />do you have to remove the cover or can you spray into the vent slits on the engine cover<br /><br />strickly preventive medicine<br />walk me thru it
ICEMAN
Re: spray can "de carb"
Hi, Yes you have to remove the motor cover and in some cases remove the carburetor covers, depending on your motor. The de-carb goes into the intake of the engine. Some engines have special fittings to attach the can too, which makes it a lot easier
plugger
its in the water, am i better adding <br />a fuel treatment "decarb"
