Spray in liner ??
georgeroth
I have a 66 -17ft. whaler Inside is in rough shape. Does anyone suggest a spray in non skid like Rino liner or linex. I want to do it myself.
Re: Spray in liner ??
Ayuh,... Sure, Why not... Quite a few around here have done that....
Azonic
the auto parts stores also sell a roll on version of the same stuff...
I used it on the floor of a rock crawler project once and was very happy...
I have a spray on texture paint we use here at work that I will put down on my deck prior to final coat...
It adds grit without the weight..
Have also heard of tossing sand down prior to final coat too...
Str8OutTha9c
The auto parts stuff will peel right off.
Make sure you use a two part system.
Something catalyzed if you really want it to work out and not peel off as easy.
