Spring - Mercruiser 470's
blkzoe
The thunder of Spring. Both engines started right up. Good oil pressure, temp stable at thermostat temp, excellent coolent flow, electrical system charging, stable idle at 750 rpm. Engine oil & filers changed. Outdrives (A1G1) drained and refilled with lube. Bottom paint good.
As any boat owner knows, I'VE OBVIOUSLY OVERLOOKED SOMETHING! I'm so screwed......
Has anyone ever published a spring check list a la an airplane pilot's pre-flight checklist?
Ayuh,..... Don'S Did,.....
Click the link in my signature titled Don'S Adults Only Section, 'n scroll down, you'll see the Summerization thread,...
