Spring startup
mileslong
i know this is alittle late but last year i fully winterized my outboad changed my gear lube fogged the carb and clynders stabilized the fuel everthing what steps should i follow to start up my out board next week.
crazy charlie
Re: Spring startup
Charge the battery,pull the plugs,crank the motor a few times,put plugs back in,hook up earmuffs with water on,and start it up.If the gas tanks are not topped off then do so and add some water absorber.Change the fuel water seperator if you have one before you venture out.check plugs again and if fouled from fogging clean,regap or replace them.Charlie
