Re: Spun coupler replacement question???
With a complete engine pull from the boat, will the drive shaft slide right out of the engine or do I need to remove the outdrive as well. Also, if the shaft is damaged, will I be able to replace from inside the boat or do I need to pull the drive, as you can tell I really dont want to pull that outdrive!
