wiskerchaser
- Feb 3, 2004
- 28
Thanks for all your advise. I only have one more question. If the boat still has good hole shot, can the hub still be spun? The Motor i had referd to earlier 70 hp johnson bogged down in the hole, stood noes of boat up and took off in about 8 seconds. could the hub be slipping at high rpm, or is it just not noticable at a low rpm? I was always told that if a hub was slipping the boat would rev high in the hole or under strane without speed gain is this a falls tail? also could blades be flatened causing prob, because i am having prop rebuilt if this could be prob. once again thanks for previous info.
