Spun Prop Hub
mark_fitzy
If I have a spun prop hub and if I purchase a new prop does it come with the rubber bush or do I have to purchase that seperate... I know it might sound like a stupid question, but I am new to all this.
Cheers :redface:
slasmith1
Re: Spun Prop Hub
If it is just a spun hub get the prop you have rebuilt it will cost far less and be as good as new.
and Yes the new prop should come complete.
Dhadley
Re: Spun Prop Hub
You didn't mention what size motor you have. Most new props are built today for the hub systems like the Merc Flo-Torq hub and are sold without a kit. You simply use an existing one or purchase separately. Those are called square bore props. Some of the props for smaller motors still have the rubber cushion hub.
Mark_VTfisherman
Re: Spun Prop Hub
I agree- rebuilding a prop is quite inexpensive compared to a new one and apparently I have not lived long enough yet to rebuild the same prop twice ;-)
If you look in the yellow pages (if you are near a big lake or seashore) for "Prop Shop" or "Marine Repair" you will likely find a local rebuilder who can fix your prop.
mthieme
Re: Spun Prop Hub
I disagree with the cost thing.
First we don't know what size motor or prop we're talking about.
We don't know if it's SS or Al.
The last prop I sent out locally set me back $85 which I thought was high. Some people I have talked to locally said it should run around $50, but noone could tell me where (much less who was president when they ever had it done).
For my smaller OB's (50hp Merc and under), the most expensive prop I ever purchased was under $100. I usually find used ones (Al) that are always well under $50.
Even for my Cobra, I can find props under $100.
Randybeall
Re: Spun Prop Hub
I would suggest calling and pricing first. It should not be that expensive, I think they saw the thickness of your wallet when you came through the door. Were there blade repairs involved? That can add to the tab.
