HokiePilot
- Apr 4, 2015
- 12
A little background on the boat....I have a 1990 Sea Ray and I have done most of the maintenance myself. Last fall I pulled the lower and replaced the impeller, greased everything up and and rebuilt the carb before laying it up for the winter. I did keep it running periodically so there wasn't a long sit period.
Since I have owned the boat I noticed that every so often in a high speed turn normally with a tuber being pulled the engine would rev up. I had always dismissed this as the prop coming out of the water. Now hindsight tells me it may have been something else. I randomly bump the mud bottom or trees in my lake since it is very shallow in some places. The other day I was running the boat home after tubing and noticed it had "revved up" more than normal, while at a good speed the gear slipped out and I immediately dropped it into neutral. The boat gets no forward or reverse motion while in gear and only revs.
Here are some things I have noticed:
-Engine runs fine, no knocking or and grinding noises in the drive
-Shifting cables from the handle to the engine all appear to be operating correctly
-There is no apparent "clunking into gear noise" when shifting into forward or reverse
-When engine revs impeller still spews water out of the prop hub and seems to be operating correctly
-With the engine off and in gear, the prop wont spin, in neutral it spins freely
Thanks for any help or insight you can provide!!
-Zack M
-Zack M
