bullsnot
- Aug 22, 2012
- 57
I have a strange problem that started to pop up towards the end of last year and has gotten worse this year. The boat starts and idles great. When the weather is cold I have no problems. When the weather gets hot though I have a problem with major sputtering at heavy throttle. I can punch it from idle and it will get up and go for a few seconds but about the time I start to plane it starts sputtering badly and if I don't back off the throttle it will die like its fuel starved. Whatever the problem is, it is getting worse. The problem used to be very intermittent but has grown into a very consistent problem to the point I can't really use the boat anymore.
The boat is maintained by the book and all service such as tune ups, filter changes etc have been done this past spring. At first I thought maybe the fuel pump was dying but generally it seems when a mechanical fuel pump goes it just stops pumping fuel altogether. I also thought maybe it was a fuel pick up issue but I have 2 fuel tanks and it's doing it on both. The hotter it is outside, the worse it gets. Any suggestions?
88 Bayliner Ciera 2450 5.7L OMC
