Srarcraft Holiday Running Hot
Captin Hook
Help
I have a 1970 Srarcraft Holiday 18' Runabout it has a Chevy 153 cuin 4 Cyl engine with Mercruser outdrive. My problem is it is now running hot the only number on the out drive I can find is 3842014 B I cannot find any model or any thing else on the drive unit. Does anybody know what pump kit this out drive uses? Any help will be apreaciated.
Thank you
Re: Srarcraft Holiday Running Hot
Help
I have a Srarcraft Holiday 18' Runabout it has a Chevy 153 cuin 4 Cyl engine with Mercruser outdrive. My problem is it is now running hot the only number on the out drive I can find is 3842014 B I cannot find any model or any thing else on the drive unit. Does anybody know what pump kit this out drive uses? Any help will be apreaciated.
Thank you
Ayuh,... Welcome Aboard,... What Vintage is it,..??
Ayuh,.... I believe there's 2 different water pump kits for the ole MC-1s,...
1 for the pumps with the water screw in the side of it(which I'm thinkin' yer's is)...
And the pump housing Without that screw...
