sst prop for tracker targa 185 with 175 hp optimax
roman
I want to by sst prop instead of aluminium black max 14.25X21. Curent result with aluminium prop. 5500 rpm .gps speed 50.3 mph. At the same time standart sheedo shows 55-56mph
My boat 18.5 deepV 98"beam. 1470lbs hull weight.I want to change the prop to have a maximum top speed by gps and a good fuel economy (mpgal) at cruising speed (3000-4000rpm) . What kind of sst prop will i preffear in my case? tempest, turbo1 or lighting, ven sure , enercia or somthing else? I tend to by with 22-23 pitch. May I change the diameter? 3 or 4 blade?
roman
Re: sst prop for tracker targa 185 with 175 hp optimax
The AV plate of my 175 optimax now is 2.5" above the down off hull. At speed it was fully submerged in the water (2-3" off water over the AV plate). I have a problem with purpoising with alluminium black max 14.25X21 in turns/. I have to trim down before turns . How can I serve this problem? I want to by sst prop for beter top end performance and to avoid purpoising in turns. What kind off sst prop is beter to by in my case? May be i must by 4 blade prop and raise motor higher? I dont want to lose top speed. Beter to increase a lot.
p.s Sorry for my bad English.
