St. louis MO / IL
SeaRyan
Is there anyone in this area that might have a 3 jaw slap hammer that I can borrow to remove a gimbal bearing. :confused: <br /><br /><br />Thanks
Re: St. louis MO / IL
A Piece of 1/2" "Redi-Rod",.....<br />An Old Sledgehammer Head,......<br />A Couple of 1/2" Nuts,+ Washers,......<br />And,... You've Got a Slide-Hammer.............. :rolleyes: <br /><br />No 3 jaw Needed,.............<br /><br />Push the Rod thru the Bearing,+ Install Washers,+ Nuts on the Inside of the Bearing............<br /><br />Hammer Away,........ Good Luck...........
