stained seats on giastron
Post a pic so we can see exactly what youre dealing with
pppsmurf47
Will get a pic all seat mildew stained used bleach and water on one jumper seat worked good don't like the bleach Thanks for the help
iggyw1
Ensign
When I had mildew stained seats at one time, I used Murphy's oil soap in hot water and it desolved the mildew at once. I also had stained seats from life preserver bags when I bought them new and set the bags on the seat. Nothing would remove that stain, so I purchased some vinyl paint and spray painted the seat white with it. Never could tell that I spray painted the seat and when I sold the boat after 8 years of my use, the seat still looked great.
crazy charlie
Diluted bleach will work best as long as you avoid the thread.if you cant avoid the thread ,saturate threads with water prior to starting.spray the diluted bleach solution and wait no more than 1 minute and rinse the threads thoroughly.do this as many times as it takes to get rid of all mildew.a magic reaser will finish the process.saturate the magic eraser with armorall or formula 303 instead of water and rub away!!
the magic eraser is nothing more than 600 grit sand paper in a sponge form, i would not use it, it does damage the vinyl.
wahlejim
Master Chief Petty Officer
My .02 regarding seat cleaning. We have all seen mold and mildew on seats. We all know it is a pain to get rid of. I think bleach is an essential step as it is a biocide and kills any living "thing" in relatively small quantities, yes, even humans. There is a reason they don't use chlorine gas to treat swimming pools like they used to back in the early to mid 1900.
After the bleach application, there may be staining left. There are a wide variety of products to use, but they all have their own drawbacks. Murphy oil soap is great, but you want to ensure compatibility with the vinyl on your boat as it can cause discoloration and staining. All other methods can be used and depending on the severity of the staining, abrasives such as magic erasers can be effective, but damaging on a small level. Whatever you use to get rid of the staining is going to be damaging on a small level. The trick is to use preventative maintenance to not have to use that same method frequently.
Do whatever works best for you with the physical capabilities and time restraints that you have. After it is clean, put 303 on it as a preventative measure, also helps restore some of the luster of the vinyl. Develop a regular regimine for preventative maintenance. For me, about every 2 weeks my pontoon vinyl gets treated. I usually look for rain in the forecast, mix up about 2 oz of chlorine in a 2 gallon sprayer, soak the vinyl and carpet down with the mixture about an hour before the rain hits, rain rinses it away. When dry, 2-3x per year, it gets treated with 303 after it dries. It is best to kill this stuff before it grows.
In your case, I would recommend what I do with my sea ray. Same mixture on a sunny day. UV light breaks down chlorine and renders it harmless. Soak everything down. Let sit for 10 minutes, wipe it down with a wet rag and clean water bucket and you are good to go.
jkust
Magic eraser works too well because as mentioned, it's sandpaper at the end of the day. I'll toss out trying some Marine Spray Nine given I don't know the extent of what you are dealing with.
