stainless bolts for thermostat housing. Good Idea?
wcasey5
1988 3.0, OMC Cobra. I'm changing the Impeller and thermostat and I was wondering if it would be a good idea to go with stainless steel bolts for the thermostat housing. Or should I stick with the originals. I was worried about corrosion, but if they react with the housing and get stuck then that's not good either.
Re: stainless bolts for thermostat housing. Good Idea?
Ayuh,... They've been workin' just Fine for 24 Years,....
Lou C
If you're worried about corrosion, coat the threads with OMC gasket sealer or the Merc equivalent, or even marine grease. I use the OMC gasket sealer on any bolt in a wet or high corrosion area and it works great even in salt water.
wcasey5
thanks! That is a great idea
