1) Performance issue you are trying to correct.
Trying to get the most speed and take advantage of the remaining wot rpm.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Turning Point Hustler aluminium, Yamaha aluminium previously.
3) Current prop diameter and pitch (required).
Turning Point: 10.375x11 Yamaha: 9.875x10.5
4) Wide open throttle RPM and speed with an average load (very helpful)
Turning Point: 5650-5750@26.7mph. Yamaha: 6200@27mph
5) Engine/drive make, model, year, and HP
2015 Yamaha F25
6) Boat make model, year, length and weight
2015 Lund SSV-14. 14'2"@300lbs
Went from the Yamaha prop that would overrev and initiate fuel cut to half inch more of pitch cupped with the Turning Point. With this change the boat handle better and is usable with just myself, had huge ventilation issues with the Yamaha prop.
Would like a recommendation for a stainless prop as my lake is very sandy and within a year eat the paint off my aluminium props. Would like to get some rpm back in the process. Not sure if I should drop pitch or stay at 11 and go stainless. Read so many contradicting statements, some say you gain rpm while others that you lose.
Currently interested in the Turning Point Express 10.125x11, good choice?
2015 Yamaha F25
