Stainless prop on rinker captiva 192
jminz
I have a 2005 rinker captiva 192 4.3L. Looking for folks with same boat and which stainless prop you are running and what pitch.
I don't have the luxury of trying multiple props so I need input before buying. Thanks in advance.
Bt Doctur
What are you running now
What is the max rpm attained?
Better off with Alum, less things break
jminz
I'm running a blackmax 19pitch aluminum. Hits rev limiter at 5k.
I know I'll need to pitch up to 20 at least, but I would really like to go to stainless so was hoping to see which one others prefer.
Tail_Gunner
Post the gearing on you leg your current speed's we know your rpm levels....Is this a carbed or efi engine?
jminz
1.81 ratio. Max rpm at 5k when rev limiter kicks in, assuming my tach is right. Top speed is 42mph. It is carbed.
Tail_Gunner
21 pitch solas or stilletto. If that boat had a light load when you posted your number's maybe a 20 pitch for a heavy load.
Below is a guide line that will get you very close to optium
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
