Speaking very basically the ss prop will have a better grip it may actually lower rpm when replaced in the same demension. Depending on where your at you would lower the pitch with the ss.The ss will resist ventilation as well.The ss is also a little harder on the drive train especially if you run into something.
I believe a similar ss prop will yield more rpm than aluminum. The blades are considerably thinner so will see less friction in the water. More rpm will mean more speed.
The stainless is more efficient, loads the motor more.It has a finer edge and stronger blades and usually a more sofisticated design.It operates closer to its theoretical performance capabilities than an aluminum.It will generally lower rpm when replaced in the same demension.But it may still increase speed depending on the present rpm.Generally it is recomended to drop in pitch when going to stainless.Again depending on the present rpm.
