Stainless vs Oem Prop!
magtec
I just put on a Express SS prop same pitch as my OEM but it seems to be not the same pitch! PPMs to high and there is no hole shot!
Silvertip
Re: Stainless vs Oem Prop!
Prop design is a "science" and just because you have two props with the same pitch doesn't mean they will perform the same. Changing from aluminum to stainless is one parameter that affects performance. Blade design, rake, vented or not, cupped or non-cupped are all factors that can affect performance. If the engine is mounted too low or too high it can affect performance. As a starting point, the AV plate should be at least even with or slightly above the bottom of the boat. Some props simply don't perform or perform differently on different hulls. I realize this isn't much help but you need to be aware of what can happen when selecting a prop.
magtec
Thanks, Well I think the rpms are up 500-600 to much with the SS 17 pitch.I am going to put back the OEM and get a good reading on the Rpms. I gues I could go up , the next pitch up is 19. <br />Just wondering if anyone has had the same out come<br />when going from OEM to SS
gr8rg8r
Going with a higher pitch will probably not lower your wot rpms by 500 - 600, probably more like 200. And, it will hurt your hole shot. Is the diameter of the SS the same as the aluminum? I would venture a guess that you went with a prop that has too small of a diameter.
bigbrownbuku
Master Chief Petty Officer
im surprised you could see a greater difference of 600 RPM. what is you outboard model and what were the original RPM with the oem prop?
magtec
I put back the oem and my full wot trimmed up is 5200. With the SS it was 5500 not full trim, I did not want to rev the motor any higher . Its probably a 300-400 rpm diff.<br />The SS is the same dio as OEM? could be just the design of the prop?
JB
Gone to the Prop forum.
Dhadley
BenC, the make and model are a secret......
walleyehed
You mention in your other post "OEM Steel"...that doesn't add up...nor does 600 more RPM and a sucky hole-shot.<br />Would you please give us the numbers of the "OEM" and the Model and pitch of the "new" prop?
Dhadley
If it's the 225 he'll want to get closer to 6000. At 5500 I'd expect the holeshot to be lacking too.
