Stalling at idle
Swampy1229
Hello to all...I have a 2009 Mercruiser 350 Magnum MPI serial # 1A348648 the engine performs perfectly with the exception of a stalling issue at idle usually only on initial cold start up. Runs for about a minute and then stalls.....
starts right back up and then she will surge a few times until I keep her running with some added throttle. I have changed the IAC , safety lanyard is operational, cleaned main harness connections, disconnected the shift interrupter. I don’t think it could be the neutral safety switch??....any ideas?
alldodge
Only with cold start I would suspect the ECT sensor. If sensor is telling the PCM that coolant is warm then it will lean the fuel supply, when motor is cold it needs to be richer to keep running. Start with the motor cold and measure the resistance with the leads removed
These are approximate values in degrees F
210 185 ohms
100 1800
70 3400
40 7500
20 13500
QBhoy
Ohhh. Surely a diz cap issue. Would be great to see a top of the page write up on how often the diz cap causes issues like this on the MPI. Such a well known issue now.
