--------------------------------------------------------------------------------<br />I am off to a bad start! 99 250 ox66 had high idle that would not go down, my tech replaced idle sensor on top of starboard head, start engine , same high idle, tech swapped thermos from one side to the other, which corrected problem, tech replaced thermos, next day engine was bogging down and stalling, discovered fuel leak from VST tank, tech replaced VST gasket and cleaned o2 ( which now makes arcing sound), Engine now starts nice with good idle and no fuel leaks, I left dock and after about 10 min. engine started stalling/hard starting. Can it be that fuel pump let go at same time gasket blew out?
