I have a 1991 Merc 5.0 350 V8 . The motor runs fine and starts every time on the first crank. The carb was rebuilt this spring, as well as primary and secondary filters changed and a water separator . The idle is perfect at b/w 650-700 rpms. Here problem: The motor stalls when shifting from Fwd to Reverse Docking. This happens almost ever time pulling up to dock. There is nothing worse! Is there a adjustment on the throttle cable, or maybe cable needs lubed? I know while shifting there is a monetary stall. But cat figure out the adjustment to keep it from dieing. Any help is greatly appreciated!!! I can only put so many more dock scratches on the boat
