Hay Boater
- Apr 20, 2021
- 3
Hello, so after doing a tune up it the starboard riser is noticeably hotter than the port to the touch when using checking with muffs. Had it out once this year and risers were fine. Installed new: impeller kit with housing, shift bushing, thermostat, plugs, wires, dist. cap, and coils. Everything is working fine except the one riser gets warm at mid-throttle. This is a raw water system that's only lived in freshwater lakes of the mid-west.
Have not had it back in the lake so today I did a tank test and noticed reduced water flow out the starboard transom exhaust at times. Temp gauge came up to 160° F and stayed right there. Took the hose off the t-stat housing to the riser and can easily blow air through it. Running different RPM's I noticed different flows. @ 950 RPM's they were equal in flow and temp, @ 2,400 RPM equal in flow and temp, @ 1,800 RPM reduced flow starboard side and hotter riser.
Do I have a problem or is this normal? Thanks in advance for the advice!
