Starboard Temp Sender connection point on 1994 XR4 Black Max 150HP Serial #0B276344
dsford1982
Hello,
When I got my motor the starboard temp sender was gone. I have purchased one bit not sure where it plugs into the wiring harness.
Can some one give me a connection point/wire?
Thank you.
Dan
Dukedog
There should be a TAN wire with an eyelet coming out of tha harness. It should go to a plastic term block just above tha start solenoid screwed to tha block. Tha tan should be on tha Isolated screw. NOT tha screw that holds tha block on! That's where tha sensor terms with tha tan.
JAN. That serial number is probably "87 or '88 model.........Last year of XR4 was either '90 or '91.
