tinkertinker
- Jun 8, 2007
- 50
I finally got around to replacing the floor in my 1971 Holiday. I'm not doing a complete re-do yet.
As promised, I'm not using plywood, but wood planks. I chose cedar because I got some cheap, and it is rot-resistant. I don't care that it will get dents in it. This boat sits outside for now, and I have this amazing benefit: if a plank rots, it comes up with 4-6 screws and gets replaced!
I intentionally left a small gap between each board to let the air circulate.
First, I created stringers from aluminum angle. Each piece of angle was custom cut, with notches to fit the longitudinal stringers, and tapered at the end to meet the ribs properly. I think you'll be able to see the method from these pics.
Thanks to the folks here for inspiring me. More pics later.
I had intended to use 1in square aluminum, but was confused about how that might affect the sideboards and such, since it would elevate the floor one inch if I wanted them to sit in one piece, running port to starboard across the top of the two longitudinal stringers.
A word on aluminum... onlinemetals beat the pants off of any of my local suppliers on price.
